by Dyan1969
My internet connection is very strong and connected , but it says it's connected
It says it's connected with problems..... Yet every trouble shoot hasn't worked , I'm agoraphobic and need my internet connection, as I can't do anything without it.... How can I fix this
by Dyan1969
Solution
Re: My internet connection is very strong and connected , but it says it's conne
It's back on now mate, there was a connection problem on their side and was
fixed yesterday thanks
What says "it's connected with problems"?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
by Profile closed
Not applicable
Hi @Dyan1969
Are you having any problems connecting to social media apps like Facebook, WhatsApp, Instagram or others ?
Sorry! Ignore this post!!
Thanks 👍
BustaCrabb
by Dyan1969
Solution
by Profile closed
Not applicable
Hi @Dyan1969
Great stuff 🤗
Thanks for letting me know! 👍
Cheers
BustaCrabb 🦀
