by pekyeye8 Contributor
My internet connection is slow and its not workings properly
Ok guys, so.. i have your internet for 3 months now and i've never had so much problems with internet instead of you.. wheb i wake up the first thing last 30 days that i need to restart my router to get internet going. Secound, my internet connection is soooo slow, i took 80-85mpbs if my memory serves me or it was 75-80 nvm.. i go check almost everyday on sleed test how is the speed and its dissapointing, so can you please send someone to fix this or can you stop charging me 30p/m. Thank you!
Re: My internet connection is slow and its not workings properly
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
54516395_444504929624097_6289388278189654016_n.jpg2.54516338_990517157813601_6881202091172298752_n.jpg3.  https://www.thinkbroadband.com/speedtest/1553089274879718155?fbclid=IwAR1W4nOHfoVNm76OjnV8sHhRTSTuQR...
And i already did factory reset and nothing happend.
Sorry, not the Event Log but the Information from the Technical Log. OIC!
Morning @pekyeye8
Have you reported this to our Broadband Gurus?
They will be able to get this looked into for you.
Thanks, Leanne.
I did put like 3 times but your site and your internet are the the world fastest so you cant even see how good it is
