by Av2
New Member
My broadband keeps dropping out, watching Netflix the sound goes then it stops.
My EE broadband keeps dropping out. Watching Netflix the sound goes off then a message appears. Leave it 5 mins it’s back on lasts 10 mins then stops again.
also have the same problem when I use the laptop. I’ve been waiting 2 weeks now, EE was sending an engineer out but cancelled it without notifying me !!!!!
any help would be great as this is very frustrating now.
Re: My broadband keeps dropping out, watching Netflix the sound goes then it sto
Hi @Av2,
Are you only experiencing this issue when using the Netflix app?
James​​​​​​​
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
