by Findog69
My broadband keeps dropping out and end up of 4G.
Hi everyone. I've just up graded to super fast broadband and am having no end of problems with signal going from 60 +mbps down to going completely off and phones only getting 4G. I've hard wired my PC to the router and even that's dropping. Had help from nice lady at EE who reset router and settings for it but now even worse. Here's a pic of speeds which vary a lot. Can anyone help.Screenshot_20181026-222740_Speedtest.jpg
Re: My broadband keeps dropping out and end up of 4G.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
