by ConorJ
My broadband is slow`
My internet is only getting 1-3 mb/s. I know that's probably because where I live, but can I speed it up in anyway?
Re: My broadband is slow`
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
