by wirralwoman
My Wi-fi keeps dropping when I’m using my smart tv especially after midnight any
Re: My Wi-fi keeps dropping when I’m using my smart tv especially after midnight
You sure it's the WiFi & not the BB itself?
@wirralwoman Is it just the TV or do your other device loose connection also ?  Sounds crazy but when did you last restart the router ?  Turn it off for 30+ seconds before restarting it.   How hot is the router getting because heat can cause issues.
by wirralwoman
everything else slows up, but i only really notice the tv due to streaming, my laptop also disconnects, I recently had a what I believe to be a mobile phone mast erected 20 yards away from my living room window do u think that might had any effect ? i restarted the router 15 mins ago
Hi @wirralwoman
20 yards? It might be the radiation from the mast.
Have you tried changing your WiFi channels on your router? You will need to connect your devices again. I would also download one of the many WiFi analyzed apps to check your WiFi strength .
Hi @wirralwoman,
Welcome to the community. 🙂
Have you tried @Northerner's suggestion of changing your WiFi channel?
Please let us know which router you are using if you need any help with this.
