by AspiA Established Contributor
My EE
I can only use either the my EE or the EE website using data, not WiFi anybody any ideas.
Re: My EE
What WiFi are you connecting to?
Re: My EE
I’m using my home broadband, don’t want to mention the name but it’s not EE.
Re: My EE
@AspiA : It's a router / WiFi issue.
1. Please post your full router stats.
