Highlighted
by Investigator
My EE router
My internet was working perfectly fine  has been since I got them all of a sudden this morning it has stopped working I cannot contact we had my mins don’t work as it cost 25p I have also tried resetting me router and turning it on and off and still not connecting I have not turned WiFi off all deviced and switched the router off at the socket advice please
Highlighted
by Investigator
Solution
My router
Sorted it I turned everything off for about 2/3 hours switched in back on about half hour ago and all works again fine still no clue as to what happed
8 REPLIES 8
Highlighted
Re: My EE router
What does it say after you log into the router:
  • For a BrightBox: in the Internet section on the initial Status page or
  • For a Smart Hub: on the Advanced Settings / Broadband / Internet page?
Obscure your names in the BB Username but post the 1st 2 parts of the IP addy. This will tell us at which stage EE have got to.
Is this for ADSL BB or Fibre? Which router, BrightBox 1 or 2 or Smart Hub?
Does the phone work? Do you get a dial tone? Does it announce your correct no. when you dial 1470 17070?
Highlighted
Re: My EE router
@Cookeeleanor27
Try checking your local network for issues.
Thanks,
Highlighted
by Investigator
Re: My EE router
Thanks just done that it’s say there not issues
Highlighted
by Investigator
Re: My EE router
It doesn’t make sense as I don’t pay my bill till 1st so it can’t be that.before I turned it off at the socket the light was red I followed the instructions for the red light which was resetting I did that and it turned red again I’m lost
Highlighted
by Investigator
Re: My EE router
Sorry I don’t understand Iv never log into my router didn’t know I could i don’t have access to a computer either
Highlighted
Re: My EE router
Is this for ADSL BB or Fibre? Which router do you have, BrightBox 1 or 2 or Smart Hub?
For a BrightBox: login at http://192.168.1.1 with username 'admin' & admin password given on the label on the router (unless you've changed it to your own one).
Highlighted
by Investigator
Solution
My router
Highlighted
Re: My router
@Cookeeleanor27: Most likely an eng working on another line disturbed yours but noticed it later.
