by ECOMELEC Contributor
My EE TV Brightbox will not connect to my samsung TV
i can not get my EE Brightbox to connet to my Samsung TV i've have try the boat- focus-dry password and the one on the back of the box but it keep saying for the security key ??
8 REPLIES 8
how do you log out of the COMMUNITY
two question one how do i get the EE brightbox to connet to my samsung TV and two how do i log off or out of the COMMUNITY when i've just posted a question .
by Brilliant Contributor
Re: how do you log out of the COMMUNITY
@ECOMELEC, You will need to go into settings on you TV and look for Network settings and connect from there. You will be asked for your password for your brightbox, but you must make sure you can connect, either Wifi or with a cable to the Internet.
If you want to log-out of the community, then go and click on at the top left of the page, where you click on where to log-in then click on that and you will see you can click log-out.
what password are they saking for the EE acount password or my Brightbox password ?
Re: My EE TV Brightbox will not connect to my samsung TV
This is an old thread but might offer some direction: https://community.ee.co.uk/t5/Broadband-home-phone/Samsung-Smart-TV-suddenly-unable-top-the-internet...
Is your TV firmware up to date?
Thanks,
The community does not have to use the same password as for your brightbox, you can make it anything you want to, but this should not have been put in the EE TV forum, as it has nothing to do with EE TV.
Are you actually trying to find out about the password for your account or the community? These are all different things. When you signed up for broadband, you received a username and password for your log-in to your broadband which you would use to log-into your account, not the same as for the community, unless you used the same password, that is.
Just had another read, the password is the one for your brightbox, not your account, to enable you to connect to your network.
Morning @ECOMELEC
Did you get both questions answered with @Schockwave help?
Let us know if you need anything further 🙂
Thanks for helping @Northerner.
Morning @ECOMELEC
Has this worked for you?
Thanks, Leanne.
Re: My EE Brightbox will not connect to my samsung TV
@ECOMELEC: The password you need for connecting a TV to the Brightbox is the WiFi pwd as written on the label on the Brightbox & looks like 3 words separated by hyphens. It has nowt to do with your Community pwd nor the BB pwd used to connect the router to the Net.
However note the issue with Samsung TVs that was pointed out to you by @Northerner.
