by Molikel84
Moving router
Hi, I am currently redecorating my lounge and need to move my black box to the other side of the room, how do I do this?
14 REPLIES 14
Re: Moving router
What do you mean? You need an extension installing or your socket/line moving?
You can buy socket kits something like this:
https://www.amazon.co.uk/EXTENSION-CABLE-TELEPHONE-FIXINGS-ADAPTOR/dp/B00WEGT8ME/ref=sr_1_15?ie=UTF8...
Thanks,
by Molikel84
Re: Moving router
I just need a longer wire connecting from phone line to black box
EE Employee
Re: Moving router
Hi @Molikel84 and welcome to the community.
I do believe you need an RJ11 cable, but i'm sure @XRaySpeX can confirm this.
Many thanks,
Lee
by Molikel84
Re: Moving router
How do I get one please
EE Employee
Re: Moving router
Hi @Molikel84
You can purchase one from the BT Shop.
Many thanks,
Lee
by Molikel84
Re: Moving router
Even though I'm with ee,I know that's a dumb question but I am not the brightest when it comes to computer stuff
EE Employee
Re: Moving router
Hi @Molikel84
Yeah, you are fine as the cable does not have any difference to the provider.
Many thanks,
Lee
by Molikel84
Re: Moving router
Thank you so much
EE Employee
Re: Moving router
No problems @Molikel84
But before you do buy one please let me have this confirmed by @XRaySpeX.
Many thanks,
Lee
Re: Moving router
@Lee_H wrote:
@Hi @Molikel84
Many thanks,
Lee
@Molikel84
If you just want to run a longer cable then this one @Lee_H has highlighted is fine. You can get these cables from many outlets in many different sizes.
Thanks,
Re: Moving router
Yes, RJ11 is correct for extending the ADSL cable from the filter to the router, such as https://www.amazon.co.uk/Alida-Systems-10m-ADSL-Cable/dp/B0095FQ5K0/ref=sr_1_1?s=electronics&ie=UTF8... . This is not the phone extension cable that @Northerner linked - diff connectors.
@Lee_H: I don't think your 1 is right either. It has an RJ45 at 1 end. You need RJ11 to RJ11.
However it is best to keep this as short as poss. It is preferable to extend the Ethernet cable (RJ45) between router & PC.
Re: Moving router
@XRaySpeX
I know I linked to another solution as the OP was unclear in their initial post. They may want a tidier option than just a cable across the floor.
Thanks,
Re: Moving router
@Northerner: They are both cables; yours a phone extension, mine an ADSL extension. They can either take the same route; across floor or not.
EE Employee
Re: Moving router
Thank you for the clarifying @XRaySpeX of the cables.
Many thanks,
Lee
