by woodlane100
New Member
Lower Speeds than estimated
my speed dropped below estimated speed for at least a couple of weeks. any refund or reduction possible? Engineer reported that voltage surges and/or lightning strikes might be responsible. Once rectified by replacing connection box and checking CAB faults my speeds have resumed back up to 27/30 mbps from 12/13mbps.
Re: Lower Speeds than estimated
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
