by Angelacee
New Member
Losing internet whilst on landline
Why does my internet go off when I use my landline
Re: Losing internet whilst on landline
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
