by TheFradg
New Member
Is there a problem with the internet in Kingswinford
Re: Is there a problem with the internet in Kingswinford
BB issues not usually localised but down to your individual connection. What problems are you having?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
