by IanRay Investigator
Is my broadband speed being lowered?
Hi, just wanting to know if my broadband speed is being deliberately slowed down?
I have the faster fibre package, these are my router stats:
Data rate:18.50 Mbps / 35.00 Mbps
Maximum data rate:18.50 Mbps / 59.76 Mbps
Noise margin (up/down):6.2 / 14.2
Line attenuation (up/down):21.4 / 16.7
Signal attenuation (up/down):20.6 / 16.2
Many thanks in advance
17 REPLIES 17
Re: Is my broadband speed being lowered?
Could well be! How long have you had Fibre Plus BB with EE? Have you ever seen it significantly faster? When?
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker
What are all EE's contractual speed estimates given in your MyEE for BB under Your broadband speed ?
Hi XRaySpeX, I've had EE broadband since about June/July last year.
Up until about December my downstream used to be close to 70Mbps, so I know it does go faster than it is at the moment. Any advice would be very welcome, thanks.
I will when I see the info I requested.
Minimum Fibre Download Speed is 41.5 Mb/Sec
Maximum Fibre Download Speed is 76.0 Mb/Sec
Minimum Fibre Upload Speed is 10.9 Mb/Sec
Maximum Fibre Upload Speed is 20.0 Mb/Sec
Minimum Guaranteed Download Speed is 35.00 Mb/Sec
I can't seem to copy and paste the table from the broadband availability checker?
You should be able to. It might come out messy but we are used to it.
Better still can't you post an image using the Photo button above your reply?
Featured Products
VDSL Range A (Clean) VDSL Range B (Impacted)
Featured Products
Downstream Line Rate(Mbps) WBC ADSL 2+Up to 17.5--16 to 19.5Available----WBC ADSL 2+ Annex M Up to 17.5Up to 1.516 to 19.5Available----ADSL MaxUp to 8--7 to 8Available----WBC Fixed Rate2----Available----Fixed Rate2----Available----Observed Speeds VDSL Max Observed Downstream39.99 Speed (Mbps) Max Upstream Observed18.6 Speed (Mbps) Observed Date2019-02-16 OtherAvailability OfferingsDate VDSL Multicast------Available----ADSL Multicast------Available----Premise environment Status Bridge TapY VRIN NTEFaceplateN Last Test Date07-02-2019
ADSL Products
FTTP is not available.
This line is on a Market B Exchange.
Downstream Line Rate(Mbps) HighLowHighLow
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
8064.2201958.1AvailableAvailable--
8059.1201750.3AvailableAvailable--
33030--Available----
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
https://www.dslchecker.bt.com/adsl/adslchecker.TelephoneNumberOutput
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC FTTP Availability Date
Availability Date
WBC SOGEA Availability Date
Left in Jumper
Left in Jumper
E6A42A2E-3BED-4A00-B68B-866DB32E7719.pngThis might be what you’re looking for!
Thanks. It does look like you are not currently getting what you should. Was there any work done on your line or in the neighbourhood around Dec. when this all started?
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats & System Uptime when plugged into test socket.
Unfortunatley I have one of the old BT sockets, was suprised at the time they didn't change it.
As far as I know there hasn't been any work done on the line, and having done the quiet line test there's no noise on the line at all. Thanks.
Even so are there any other phone extensions in the home? It might be worth asking EE to "normalise" your master socket to a modern NTE5.
The DLM system has put you on a banded profile presumably in response to past errors on your line, at the top of the up to 35 Meg band of these VDSL Banded Profiles, altho' you now have no significant errors. You need to give the DLM time to relent & remove any banding. If your sync speed at the test socket remains stuck at the same speed for 10 days you should ask EE to investigate the underlying fault. If a fault is found and fixed then the OR engineer may request a DLM reset. However should significant errors persist the DLM will reapply banding.
So is it possible the DLM has become stuck?
All I know is my sync used to happily sit at 65-70Mbps, and in the last couple of months or so hasn't gone above 49Mbps. It's now the lowest it ever has been.
I have no other extensions in the home at all.
It sometimes, rarely, happens with VDSL; used to be more so with ADSL.
At the mo' your sync speed equals EE's Guaranteed Min. (which I can't think where they dredged that up from; according to BTw it should be 50 Meg). Once it it drops below you'd be justified in demanding EE fix it & reset the DLM regardless.
I will get onto EE and see what they will do. Thanks very much.
Been a while so I thought I’d update this. One new master socket MK4 later and all is fixed and working very well. Well happy!
Picture won't seem to upload so my my router stats are now as follows:
DSL uptime:0 Days, 0 Hours, 54 Mins, 35 Secs
Data rate:20.00 Mbps / 79.74 Mbps
Maximum data rate:21.07 Mbps / 79.96 Mbps
Noise margin (up/down😞6.1 / 3.4
Line attenuation (up/down😞18.6 / 16.7
Signal attenuation (up/down😞18.5 / 16.7
Data sent / received:
That's more like it! So you managed to get EE to "normalise" your master socket? Well done!
Yes, the engineer took one look at the socket and decided to change it. I guess the rewiring may have helped things...
