Highlighted
by Contributor
Is broadband working in PO33
Is there a problem with broadband at the moment. I get good signal but web sites say can't be reached?
Highlighted
Re: Is broadband working in PO33
Probably! BB issues are almost invariably to do with your specific line & not your location.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
