by Beckyfriend1
Internet speed isn't as fast as what I'm paying for
  • Internet is only 27mbs yet I'm supposed to be getting minimum of 45 and paying for more!
  1.
Re: Internet speed isn't as fast as what I'm paying for
@Beckyfriend1 : Welcome to EE's Home Broadband Forum.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
