by Aidy
Internet problems
Re: Internet problems
Hi @Aidy
What problems are you having?
Hi @Aidy.
Thanks for coming to the EE Community 🙂
If you could give us a little more information on your internet problem, we will do our best to help you.
Jon
by Aidy
Hi
for the last week or so our fibre internet keeps dropping
by Aidy
Hi
For the last week or so our fibre broadband keeps dropping
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
