Highlighted
by Investigator
Internet outage
Hi Dunvegan Isle of Skye,  I have been having problems for days now with constant outages. Has any else had this problem?
21 REPLIES 21
Highlighted
Re: Internet outage
@rabk591 : On what device?
Highlighted
by Investigator
Re: Internet outage
 it happens on all devices. I can be working on the computer and, wham, no internet. It is a pain if I am working on a business file and I haven't save what I have done. Start all over again.
Highlighted
Re: Internet outage
Hi @rabk591,
Are you using mobile or home broadband?
Highlighted
by Investigator
Re: Internet outage
Hi James,
I am using home broadband.
Highlighted
Re: Internet outage
@rabk591 : Welcome to EE's Home Broadband Forum.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & numbers in the BB Username & also the SSIDs.
3. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Highlighted
by Investigator
Re: Internet outage
Sorry for the long delay. The system uptime is  295:02:22.
Highlighted
by Expert Contributor
Expert Contributor
Re: Internet outage
The answers to the rest of the requests of @XRaySpeX  would be appreciated and give us a better view of what is happening with your connection.
Highlighted
by Investigator
Re: Internet outage
Really sorry for the delay, I will send all information tomorrow 26th.
Highlighted
by Investigator
Re: Internet outage
Here is the required data.
System Uptime is: 331:06:06
Link to result, https://www.thinkbroadband.com/speedtest/1590479957854171255
 I cannot get BT Wholesale broadband checker to copy over the readings. Have you any Idea how to get it across to you?
Highlighted
Re: Internet outage
Use the Camera icon above your text to upload a file to here.
Highlighted
by Investigator
Re: Internet outage
I am sorry but I don't see a camera icon anywhere above the text on the bt readings. I have tried to copy and paste from my clipboard but that does not work either even after I have updated the computer. Any other ideas?
Highlighted
Re: Internet outage
Are you on a mobile? Either do it from a PC or put the mobile's browser in Desktop View. Then you'll see it.
Highlighted
by Investigator
Re: Internet outage
I am not on mobile I am on my PC. I have even tried to do a screenshot but that will not work either. I am sorry for all these problems I am giving you. Could it be because I am not with BT for phone or broadband?  Maybe you could you send me a screenshot of where this camera icon is supposed to be. If that is not possible I don't no what else to try.
Highlighted
by Investigator
Re: Internet outage
I don,t no how I have done it but I have manage to copy and paste.
Telephone Number  on Exchange DUNVEGAN is served by Cabinet 1
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
45.9308625Available----
44.1257.85.420.4Available----
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 16--8 to 19.5AvailableAvailable--
Up to 16Up to 1.58 to 19.5AvailableAvailable--
Up to 8--7 to 8AvailableAvailable--
--------Available--
2----Available----
Observed Speeds ADSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
19.21
1.08
2020-05-26
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
FTTP is not available.
Highlighted
Expert Contributor
Re: Internet outage
What do you mean a screenshot won't work? Have you got the screenshot? If so click on the camera to add your screenshot. You will have to wait for a mod to allow it to appear.2020-05-26 12_21_39-Post a community reply - The EE Community.png
Highlighted
by Investigator
Re: Internet outage
I have now found away to copy the image to the message body but when I preview it before I send it it only shows a triangle. It basically tells me that the html in not recognized.
I will try and send it by email instead.
Highlighted
Re: Internet outage
Don't worry, your images were awaiting approval. Upload it again & I will do so & they should appear soon.
Highlighted
by Investigator
Re: Internet outage
Hopefully you can do something with this. I did send an email with the file but maybe you did not get it.sHopefully you can do something with this. I did send an email with the file but maybe you did not get it.s
Highlighted
Re: Internet outage
Thanks. You've got the hang of it.
I still await the most important info, the full router stats.
