by Hoggy5724
New Member
Internet issues?
Hi, I'm having internet issues in the mayfield dalkieth area it's been dropping off all day. Is anyone deals had similar issues? EE checker says no problems in my area.
Re: Internet issues?
Which EE Checker? The EE Network Status Checker is only for the mobile network.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
