by TommyAwesome Investigator
Internet Speed dies when uploading.
I've been with EE broadband for a couple of months now. When I'm not uploading, everything is fine and I'm getting a quicker download speed than I did with BT.
However, when I start uploading to Onedrive, it kills the download speed for everyone else. The upload speed is rubbish as well, but I could live with that if the download speed wasn't affected.
My average download speed is around 7mb... but when I start uploading, (upload speed rarely goes about 500kbps), my download speed is less than 0.5mbps.
WHY IS THIS! It never happened with BT!
I've tried limiting the upload to 50kbps via the router, but it doesn't make a difference.
If this continues, I'll be looking for ways of cancelling my EE contract as ths really isn't good enough.
20 REPLIES 20
EE Community Team
Re: Internet Speed dies when uploading.
Hi @TommyAwesome,
Welcome to the community 🙂
I would suggest speaking to our technical team about your speeds.
They will be able to view your account and are in the best position to be able to resolve this for you.
Alex 🙂
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
1 / DSL STATUS (with upload paused)
This page shows information about your DSL connection. If you are using Fibre/Ethernet Broadband then this page is not applicable.
STATUS  Configured CurrentLine StatusLink TypeOperation Mode
--UP
--Interleaved Path
AutomaticG.992.5 (ADSL2+)
DATA RATE INFORMATIONUpstreamDownstream
770 (Kbps)
9405 (Kbps)
DEFECT/FAILURE INDICATIONOperation Data Upstream DownstreamNoise MarginLine Attenuation
5.6 (dB)4.8 (dB)
19.9 (dB)42.0 (dB)
Indicator Name Near End Indicator Far End IndicatorOutput PowerFast Path FEC CorrectionInterleaved Path FEC CorrectionFast Path CRC ErrorInterleaved Path CRC ErrorLoss Of Signal DefectFast Path HEC Error STRInterleaved Path HEC ErrorError Seconds
12.2 (dBm)20.6 (dBm)
16082835166
0662873
250
1656353419
26294168
STATISTICSReceived DataTransmitted Data
30733609 (Kbits)
30863294 (Kbits)
DSL STATUS (With Upload running)
I get an "ERR_CONNECTION_TIMED_OUT"
2 /
7.7 download, 0.5 upload (my upload task is paused.)
When I start the upload, the speed test page becomes unresponsive.
3 /
My exchange is Kingston St Mary, Somerset, (WWKSTM).
This never happened when I was with BT... all internet access shouldn't stop when I'm uploading!!! I'd accept a little slowness, but i may as well not have internet now!
System Uptime please.
System Uptime is: 107:48:42
Hi there @TommyAwesome
Have you spoken to our Broadband Tech team to get your speeds looked into?
They will be able to help you get this looked into further.
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats & System Uptime when plugged into test socket.
I don't think I have a test plug... I have a filter built into my BT socket and the router is plugged direcntly into that.
Re. the quiet test... I ran that and all was quiet.
When I'm uploading, I can't even get on to the router to get the details... I've rebooted the router in the past and it's made no difference.
I will try speaking to the technical support when I get a chance before they close... but I'm willing to try things as well.
I have a friend in the village I live in (so same exchange) and he has the same issue...
If you have a filtered BT master socket you can remove the faceplate & get to the test socket. Maybe like Linebox NTE5C User instructions - Openreach
OK, I'll give it a go later when I don't need internet access.
Although... When I was with BT... it didn't do this... I will still try the test line though.
Where you with BT at the same premises or somewhere else that didn't have such a narrow Up bandwidth?
Same place. Haven't moved. Changed to EE as they were cheaper.
I get quicker download and upload speeds with EE, just not at the same time.
As a friend in the village has the same issue, I'm wondering if it's a router issue?
I only get 7-8mb downloand on a good day. But turn on upload and that disapears and I can't even get to a google page on ANY device. turn uploads off, and it all comes back, almost instantly.
On the Basic BB Settings page what is the Protocol & MTU?
Protocol = PPPOA
MTU = 1492
I don't know what either of those mean...
Try changing MTU to 1500. It's a valid value for PPPoA. I don't expect it to have much effect but you never know.
Tried that... didn't make a difference, (thanks anyway).
It's almost like my DNS stops working.... as it says it cannot resolve the web address.
Could that be something?
Saying that, even when I try to browse to the router using the IP address, it still doesn't work... so that may rule out DNS?
When browsing - this message shows up:
This site can’t be reached www.google.co.uk unexpectedly closed the connection.
Try:
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_CLOSED
It's worth a try to get round this issue by switching the DNS in the router away from EE's ones to Manual with 1 of these public DNS:
OpenDNS   :	208.67.222.222 & 208.67.220.220
Google DNS:	8.8.8.8 & 8.8.4.4
Cloudflare DNS 1.1.1.1 & 1.0.0.1 Norton DNS: 198.153.192.40 & 198.153.194.40
