by xKimbitx Investigator
Internet Not Working
Hello, I very much love EE as a company and I really did not want to end up putting in a complaint but I just don’t think this is right.
Every month I am using up all my 4G whilst in the house, where I am supposed to have your ‘best’ Wifi.
It constantly disconnects all day every day, even when I have literally just connected my phone again. I have tried turning the box on and off again, I’ve tried numerous things but it just simply doesn’t work. Even if on the very rare occasion the connection holds long enough for me to search something, it then fails and I have to repeat the cycle of reconnecting.
I feel that considering the money I am paying for the Internet, TV, and IPhone Contract I should be able to use the WiFi and not use up all 20G of my data every month.
I really do hope you are able to offer some kind of advice or help. Thank you so much for taking the time to read this, have a wonderful day/night!
9 REPLIES 9
Re: Internet Not Working
Hi @xKimbitx
What router do you own?
Are you connected to the 2.4Ghz or 5Ghz? Try changing and forgetting the other to see if that helps.
Is it the router that is disconnecting from the BB or just your devices that disconnect from WiFi? They would be diff issues.
It doesn't do to reboot the router too often or the DLM will think your line is unstable & mark down your speed.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
by Noddy1965 Investigator
Could  u check 2c if its sumfing2do with open reach as they have internet problems in remote areas%it may b affecting  your download  speed  somewhat. Or your router,I'm no expert on this,googled it just now.
Hi @xKimbitx
Welcome back to the community. 🙂
Could you come back to us with the information that @XRaySpeX asked for?
We also have some troubleshooting steps on our broadband help and support page.
Hello! Thank You So Much for all your advice. I’ve been trying to reply to you since yesterday but my WiFi has literally only now allowed me to stay connected long enough to reply.
Strangely, the WiFi only continually disconnects on my IPhone 8 and iPad 2018 Generation. On every other device connected to my SmartHub works fine with no issues.
In reply to your questions:
1. Here is my router stats:
2. I don’t know if still need to do this? None of my laptops have an issue with connectivity and I don’t know if you can do this test on iPhone? If so I will do it now.
3. https://availability.samknows.com/broadband/exchange/WSWIS
I should state that since separating my  channels my phone has managed to stay connected for quite a while now. Hopefully this has solved my problem but I can only hope and wait and see.
Thank yiu you so much again! Have a wonderful night.
Your BB looks just fine & is running at the max speeds for standard EE Fibre, which I assume is the product you bought.
SO I think you must have a WiFi issue. Can you run the speedtest I suggested from your lappy, both wired & wireless & post the result graphs?
You could try changing the WiFi channels - see How do I change the wireless channel on my EE Smart Hub?
Thanks! You're welcome :)! Glad I could be of assistance.
I'm not an expert just some chap trying2help others as my mum&dad would do if they knew I would think they would be proud.
Hi @xKimbitx
If its just your apple products then that would suggest its the Apple firmware. I believe wifi drops when the screen sleeps to save battery power, @Chris_B might be able to offer some help as he owns apple devices.
Thanks,
@xKimbitx  How’s you connection now ?    Have you tried clicking “Forget This Network “ and then rejoining?
