Highlighted
by Investigator
Interleaving
Hello there I am looking at disabling interleaving/error correction on Fibre and was wondering if some one would be able to do this as a request so I can get the most out of what I do, not sure if this is the correct place to ask
Highlighted
by Investigator
Solution
Re: Interleaving
Hey, everything is cool, interleaving decided to switch its self off when DLM checked how mine line was doing so fortunately my line must be decent, that's awesome 🙂 I also had a 10mb speed increase instantly
11 REPLIES 11
Highlighted
Re: Interleaving
Good Morning @captainfloyd
Welcome to the EE Community.
Interleaving can't be switched off for fibre-based broadband lines (such as Fibre 100 and Fibre 250 or Superfast Fibre).
Katie 🙂
Highlighted
Re: Interleaving
@Katie_B : Why are you answering in terms of BT Retail product names. EE doesn't call them that.
Highlighted
by Investigator
Re: Interleaving
Thanks for the reply, I thought that when it came to fibre it would take an engineer to come out and be able to disable it from the box with DLM? if you could assure that this is not possible, I would be thinking about downgrading and if so a request you would be able to do this all for me? thanks again
Highlighted
Re: Interleaving
Posted in the open:
@captainfloyd wrote:
Hi Ray, I joined EE yesterday and I was wondering if you could help me and maybe get someone out that could optimize my connection for when I game, so disable interleaving/dlm/error correction, it would be great if this was possible, thanks
Highlighted
Re: Interleaving
@captainfloyd : I don't have a squad of engs to send out to you & OR are currently limiting home visits.
Highlighted
by Investigator
Solution
Re: Interleaving
Highlighted
Re: Interleaving
Posted in the open:
I got my new router all working which very impressed with how the speeds and stuff are with EE but I've noticed a problem with range, as it is installed upstairs the wifi signal for downstairs does work but netflix wont come on the TV and has a problem, I'm sure that it cant be the tv since its new but maybe it's 25/30m away from the router, even the official router, so is there a way you can put a boost on the wifi range or a different better router? thanks
Highlighted
Re: Interleaving
@captainfloyd : I'm just a user like you. I don't boost peeps' routers or WiFi.
For an EE Smart Hub try separating the wireless channels. On the Advanced / Wireless Settings page of the SH there is a button near the top to Separate the Bands. Turn it ON. Then the 5GHz SSID will appear starting with "5GHz-" & the 2.4 GHz SSID not starting with "5GHz-".
Highlighted
Re: Interleaving
Posted in the open:
My ping is at a very nice 11/13ms which I'm glad that interleaving disabled its self in the first day of having which is unexpected, but I was curious to actually see if I was either on the WBC or LLC network, and whether if I was with ADSL instead the ping times would be as low as 8ms ? the exchange is 0.8 miles away from my home
Highlighted
Re: Interleaving
@captainfloyd : You are on a WBC network with FTTC/VDSL.
Your Fibre cab. is nearer to you than the exchange.
Highlighted
by Investigator
Re: Interleaving
Hmm, yeah I already separated the bands I tried some stuff and even changed modes, but mode 1 said that it was best for range, either the new ee hub isnt the best when it comes to range in general so I'll have to find the antennas for my own router or something but it's a shame that it won't allow the netflix to run downstairs. The cabinet im on is about 0.3/0.4 of a mile from my home whereas the exchange is 0.8/0.9 a lot of people on the WBC network are able to get 6-7ms pings would you say that distance is affecting mine or something else is the factor ?
