Highlighted
by Valued Contributor
Valued Contributor
Installed bt mesh discs and my g fast home hub lost Ethernet connection?
I have g fast internet in my large house. The Wi-Fi drops off when you leave the vicinity of the EE router. I went out and bought a 3 disc bt whole home disc system and installed it as per instructions. The Wi-Fi was all through the house but the Ethernet was showing connected but no data coming through?
19 REPLIES 19
Highlighted
Valued Contributor
I Installed bt mesh discs and my g fast home hub lost Ethernet connection?
Highlighted
Re: I Installed bt mesh discs and my g fast home hub lost Ethernet connection?
Hi @paulebb
Have you set them up correctly, via the app/router?
Highlighted
Valued Contributor
Yes, as per the app?
Highlighted
@paulebb
The BT Whole Home WIFI app
Highlighted
Re: Installed bt mesh discs and my g fast home hub lost Ethernet connection?
@paulebb : Are you on the EE Max BB product using a BT Smart Hub combined G.Fast modem/router?
Highlighted
Valued Contributor
yeah, the BT wholehome app. It set up and the Wi-fi was good, but no Ethernet?
Highlighted
Valued Contributor
And yes again, using the EE hub with a bt (huwai) white router?
Highlighted
Valued Contributor
I have ended up switching off the bt discs and resetting my EE hub to get the Ethernet working, until I can find a solution.
Highlighted
Valued Contributor
I was wondering if I could connect the discs to the EE hub using the WSP button and it might keep the EE network but with the Wi-Fi range?
Highlighted
Ah, I thought you were using BT kit on an EE Max connection as you said "G.Fast Home Hub" as the Subject.
Highlighted
Valued Contributor
Sorry X Ray,
my bad, I’m not too tech savvy, lol
Highlighted
To what is the first Mesh node connected to by Ethernet?
Highlighted
Valued Contributor
Direct to the EE router.
Highlighted
What does it say after you log into the router:
  • on the Advanced Settings / Broadband / Internet page?
  • on the Advanced Settings / My Network page?
Obscure your names & numbers in the BB Username but post the 1st 2 parts of the IP addy.
Highlighted
Valued Contributor
I’ll set it up again tomorrow and I’ll let you know.
Thanks for your help, it’s appreciated.
Highlighted
OK! I'll wait on it. Thanks! You're welcome 🙂 ! Glad I could be of assistance.
Highlighted
Valued Contributor
Hi XRay,
sorry for the delay.
I hope these are the pics you were asking for?
Highlighted
Valued Contributor
Sorry X Ray,
it wont let me up load the pics of my settings?
Highlighted
It takes time for images to be inspected by the Mods & approved or not.
Please post the other image as well & we will see them eventually.
