by Mischa
New Member
Increase in latency and reduction in speed
Hi All,
I am currently on the fibre max and up until about 3 weeks ago i was getting a reliable 74-76mb download and 18-19mb upload with a 6-8ms ping with speetest.net and broadband speedtest. In fact In the last 3 years I have had this speed from BT, Plusnet and EE so this is what I know I should be getting.
Recently I have been getting wildly differing speed test results varying from 20mb-70mb dl and 4-16mb upload depending on the time of day. Online games are becoming unplayable with random lag spikes, and since nothing has changed in my setup I am at a loss as to what is wrong.
Even more baffling is that http://speedtest.btwholesale.com/  tells me my download speed is 300mb, when this is not even available in my area on the openreach fttc network. When asking for further diagnostics the test tells me 'The Tap1 test was not conclusive'.
Does anyone have any suggestions on how I can get this sorted?
A
Re: Increase in latency and reduction in speed
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Hi @Mischa
Welcome to the community. 🙂
You could also try the steps on our broadband help page.
