by SHEILAJURY
INSTALL A VPN ON A SMART HUB
Does anyone know how to install a VPN on a smart hub
Re: INSTALL A VPN ON A SMART HUB
@SHEILAJURY   You can not install a VPN on the EE smart hub.
by SHEILAJURY
How sure are you Chris as EE say its possible but cannot tell me hoe to do it
@SHEILAJURY   The VPN is on the device that’s using the router. The router is the gateway to the VPN site.
  The router has no memory to store the information you will require for the VPN.
Just to add the router is not yours to install software on and if EE push out an update for the router any 3rd party software could cause issues for the router.
Not install but you can run a VPN thro' the router. The EE SH does cater for VPNs:
