by Norrieboy
I need to get my router moved to another room, does anyone know how to go about?
by phil76012 Established Contributor
Re: I need to get my router moved to another room, does anyone know how to go ab
Either pay £135 pounds for a bt engineer to do it or buy 50m of 4 core wire and just hook it up to the existing phone socket and run it to the new socket and just wire it up.
Hello there @Norrieboy
Welcome to the community.
If you give us a call and speak to our broadband team they will see what they can do to help.
Thanks, Leanne 🙂
by Norrieboy
Thanks. I will try that. I was just worried about weakening the signai
