by Osborn-82 Investigator
I need help with my broadband
My broadband has just knocked off. It’s saying wrong password. How can I sort this
7 REPLIES 7
Re: I need help with my broadband
What's saying "wrong password"? A WiFi connection from a device or the router itself?
On all devices it’s saying wrong password. One minute I was watching tv then it went off
So that's the WiFi pwd then?
On each device tell it to Forget the connection & then connect afresh supplying the WiFi pwd, remembering that lower & upper case are diff & getting any special chars correct. A common mistake is mixing up "minus" ('-') with "underline" ('_') The WiFi pwd can be found on the label on the router.
Hi @Osborn-82
Welcome to the community.
Did you get a chance to try the steps that @XRaySpeX posted?
Look forward to hearing from you.
Spoke with ee and they have reset everything so fingers crossed it stays working. Thank you
Great news @Osborn-82
Cheers
Richard
Can't see resetting the BB affecting the WiFi connectivity.
