by Chief_DMG
I'm having Sky Q mini box lag/freezing issues
Got Sky Q installed yesterday and having some bother with the mini box. It stays connected to the network, has dropped once but seems okay, however the live TV and recordings playback is pretty poor. Can work well for a while but will start to lag/freeze almost every time. I have 38mb fibre and until now everything had been okay. Anyone have any ideas?
Re: I'm having Sky Q mini box lag/freezing issues
Is Sky your broadband provider?
It may just be your boxes upgrading but then again it shouldn't take long. Are you using your box over wifi or wired powerline adapters?
Thanks,
by Chief_DMG
No EE is my provider. The boxes are up to date and it's over wifi
Hi @Chief_DMG
Thanks for coming to community 🙂
Have you by any chance see this support article called Need Help with Your Home Broadband Speed or Connection?
Please do have a look at it and let us know how you get on.
Richard
