by ogri59
I have no dial tone on my landline but my internet is ok
Hello,
I have no dial tone on my landline, but my internet connection is fine. I have been through all the checks on the website, checking wiring etc, but no luck, can anybody help?
Solution
Re: I have no dial tone on my landline but my internet is ok
Have you tried plugging the phone in the hidden test socket?
You probably have a "one-leg broken" fault (technically "HR Dis"). A landline consists of 2 wires, both of which are need for voice, but only any 1 for BB. Usually when this happens the BB runs slower than usual.
To confirm this Please post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ (A)DSL Status. Also post 'Time Connected:' from initial Status page. Full router stats are key to any speed & connection issues.
It is likely that the break occurs between you & the exchange, but it needs EE to call out BT Openreach to fix it.
by Brilliant Contributor
Hello @ogri59
Welcome to the community,
You will need to contact EE, customer service via another phone, it is a free number, which you can find via the contact us at the top of this page.
Solution
