by cornishtales Contributor
I had my new broadband two weeks ago and my phone cuts off when I walk about.
I had my new broadband two weeks ago and my mobile phone cuts off when I walk about. What can I do?
6 REPLIES 6
Re: I had my new broadband two weeks ago and my phone cuts off when I walk about
@cornishtales   Are you using WiFi calling when it cuts off ?  Do you need to use WiFi calling ?  What is the cellular signal ?
Yes to wifi don't understand cellular reference.
I think @Chris_B is asking what your mobile phone signal is like without WiFi, @cornishtales.
Correct me if I'm wrong through, @Chris_B.
If you have a good mobile signal, it may be worth turning WiFi calling off.
What kind of phone is it?
Thanks Chris. I think I will try without WiFi calling.
@Christopher_G   Yes that’s correct. Also the device should switch between the 2 sometimes it can drop out.   @cornishtales  How good is the cellular signal on the device?  WiFi calling should only come in to play when there is a poor to no signal.   what device is it ?
Thanks for your email. I have switched off wi-fi calling to see what happens
