by DaveNicholls Contributor
I frequently cannot connect to websites or email first time.
For a month or two, I have had to attempt to connect to websites or e-mail server several times before it connects. I am on Windows 10, using Firefox and Thunderbird. I use Kaspersky Internet Security. Any ideas?
Solution
Re: I frequently cannot connect to websites or email first time.
Is it as bad when you use raw IP addys instead of URLs in your browser?
You could try & get round this issue by switching the DNS to Manual in the router with 1 of these public DNS:
Open DNS  :	208.67.222.222 & 208.67.220.220
Google DNS:	8.8.8.8 & 8.8.4.4
Norton DNS:	198.153.192.40 & 198.153.194.40
10 REPLIES 10
Hi @DaveNicholls
Welcome to the community. 🙂
What happens when it doesn't connect? Do you get an error message or anything?
I'll do my best to help.
Many thanks Chris,
I should have said my PC is connected directly to the Ethernet port on
my router - I am not going via wi-fi. With my Firefox browser, I have
started getting "Server not found" and a Retry button. This happens
perhaps every other time. After clicking on the Retry button two, three
or sometimes four times, it connects. Also when I fire up Thunderbird,
it should download any pending emails, but it often comes up with a
message "Failed to connect to server" or some such words. Then I have to
hit the Get Messages button, and this sometimes takes several attempts too.
My router was supplied by Freeserve, which of course went to Orange, now
EE! so it's pretty old, a DGN 1000. I updated the firmware in it last
night from the Netgear site, but the problem persists.
I've got a feeling the source of the problem is a timing problem of some
sort.
Yours in hope,
David
Thanks for getting back to me, @DaveNicholls.
This is a little beyond my broadband expertise.
@XRaySpeX is our resident broadband expert and may be able to help with this when logged in.
Otherwise, I recommend speaking to our broadband technical specialists to see if they can investigate this for you.
Thanks Chris -
I'll wait for XRaySpex or try the other experts.
David
Solution
Thanks XRaySpeX - I think I have solved my problem. I have an Ethernet lead from my router upstairs to one end of a TP-Link range extender (Power-line carrier) plugged into the mains upstairs. The other end of the TP-Link which has a Wi-Fi transceiver built-in is plugged in downstairs so I can use the laptop there. The Wi-Fi in the upstairs router is off. I also have my Humax PVR connected to an Ethernet port on the range extender downstairs - the Humax TV portal needs the internet.
If I disconnect the Humax from the TP-Link, my PC (connected directly to the router) connects (nearly!) every time to the internet.
I don't know what the underlying issue is, be interested if you have any ideas.
I will star rate you if I can find the flippin' star!
Hi @DaveNicholls
Thanks for posting 🙂
I'm sure when @XRaySpeX is available he will try his best to help you.
Thank you
Richard
Just a guess: Disable UPnP in the router & put the PVR back in. Any better?
Did you try my raw IP idea?
Many thanks XRay,
Turning off UPnP doesn't seem to help much, but I have now set the
router up to use Primary DNS Server = Open DNS 208.67.222.222 and the
Secondary DNS = Google DNS 8.8.8.8. which has done the trick, I think.
I think I am back to my original (pre TP-Link configuration) performance
now, i.e. just failing to connect occasionally, so I am very grateful.
Thank you
Dave
Thanks! You're welcome :)! Glad I could be of assistance.
And it's working with the PVR back in?
