Highlighted
I am new to e03 home broadband I can't get a good signal I have bought 4 wifi bo
I am new to ee home broadband and I can't get good signal I have bought 4 wifi boosters still no good what else can I try thanks
Highlighted
Highlighted
Re: I am new to e03 home broadband I can't get a good signal I have bought 4 wif
Are you getting a good BB signal & it is only the WiFi signal you have an issue with?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
