by Idr-76 Investigator
How to stand smart hub upright
Really embarrassed by this but can't figure out how to put the 2 feet on the smart hub to make it stand. It is driving me insane and I can't find anything on the wonderweb that illustrates how to do it.
Thanks in advance
Solution
Re: How to stand smart hub upright
All sorted, apparently "feet" should arrive already fixed to unit. As mine weren't the very helpful guy at customer services ordered me a new one.
I bet you all thought "who is this idiot?!"
Thanks again
@Idr-76 The feet swing round from the edge of the router.
Thanks for the reply but I get so far and the feet pop off. Can't seem to lock them in place. Now the "fitting" on the hub has dropped down into the unit.
Solution
Thanks again
