by connornathan79 Investigator
How to keep devices connect to your WiFi, constantly having to re sign in
Hi, I've not long since had ee broadband. All good with the speeds but seem to have to keep re connecting my devices, for instance, my smart tv has had to be signed back into the Internet twice this week and my done iPhone once also my wife's laptop and youngest amazon fire, all these devices we connected on or within the first few days of having we installed but have neened needed to be signed in again. Any ideas
7 REPLIES 7
Re: How to keep devices connect to your WiFi, constantly having to re sign in
They shouldn't need to do. Most devices remember the WiFi login & auto login again when they get disconnected. My Smart TV, mobile & PCs always reconnect with the WiFi.
My Devices do remember, it's the router I think. Can't be a number of devices. It all worked fine before I switched
Which router? I've used EE's both w/out this trouble.
It's the latest one, it's a large black one for the ultra fast firbe
Hi there @connornathan79
How often has this happened?
Are you connected to WiFi and using the device at the time?
It's happens a few devices a few times. LG smart tv, now tv boxes, an iPhone and amazon tablet also a hauwei p30. It seems to happen not while they're are connected. For instance, the TV was off all day and when out on in the evening, I needed to reconnect. The iPhone had been on but not used all night and needed to re connect. The p30 I came in from work it it prompted me to reconnect. The now tv boxes off all night, and when went to used in the morning had to be reconnected. This is all on separate days and separate times and not all devices on same days
Thanks for confirming @connornathan79
In this case I would suggest reporting this to our Broadband Gurus.
They will be able to get this looked into for you.
Let us know how you get on 🙂
