Highlighted
by Investigator
How to disable Internet disconnect status lights on Smart Hub
Hi All,
I have an ADSL connection plugged into the EE wireless hub.
I wish to migrate the ADSL connection to another 3rd party device. However I still want to use the EE hub simply as a wireless AP while my 3rd party device handles the Internet.
However, when I disconnect the Internet from the hub, the lights start flashing in error, even when I disable the status lights in the GUI. This is obvously annoying to me but also my family as they see a constamt flicking light.
Any suggestions? Thanks.
anniek
Highlighted
Solution
Re: How to disable Internet disconnect status lights on Smart Hub
The SH cannot be used as a pure router, You cannot turn the modem off. Therefore when the modem is receiving no BB signal the warning lights will flash.
7 REPLIES 7
Highlighted
Solution
Highlighted
by Investigator
Thats a shame. I just want to use the WiFi without the routing or the modem. Maybe 'gaffa' tape over the LEDs is the answer 🙂
Thanks.
Highlighted
You still won't be able to use it as a WAP. It can't be used as a router or bridge only.
Highlighted
by Investigator
I've managed to do it. Topology is:
Wall Socket <-----> 3rd party device <----> SmartHub <---->  Hosts (laptops/mobiles etc)
Essentially the built in switch/wireless domain are all 1 big broadcast segment. I've moved DHCP/DNS lookup to the 3rd party device also.
So basicically, the hub is working in Layer 2 of OSI (I will use to electrical tape to cover flashing lights).
Highlighted
                                   What is this connection? Wired or Wifi?
Ah, of course, you are connecting it by the Ethernet (Red) WAN. I would have thought that would take out the modem & the lights wouldn't flash.
Highlighted
by Investigator
That connection is wired into standard LAN port 1 of the Hub. The 3rd party device is non wireless (hence why I want to borrow the hub's wifi features).
I think i could solve the light issue by turning the 3rd party device into a mock ppp server and then plug it into the RJ45 WAN port 4 of the hub, then enter custom credentials to trick the hub into thinking its authenticating with the POP, but seems a lot of effort for a cosmetic issue. I might try it for fun sometime 🙂
Thanks for the advice XRAY
Highlighted
I would have thought it'll work & the lights go out if you simply move the SH's Ethernet connection from port 1 to red port 4. The other router will have already authenticated to EE's network.
