Highlighted
How many devices connected to fibre broadband?
I have been an EE customer forever but over the last year have gone from one problem to the next. I have the 4GEE fibre broadband router. On a good day I get speed of 45 (should be 65). However the constant dropouts are driving me crazy. Spoke to several EE engineers and the last thing they are telling me is that 13 devices on WiFi is too many and I should have 2-3 WTF?? Is this right? If so I need another provider - any recommendations?
Highlighted
Re: How many devices connected to MOBILE broadband?
There's no such thing as 4GEE FIBRE BB. You either have a mobile BB router running over the EE mobile network or a Fibre BB router running over a landline. Which do you have?
If you are talking about the 4GEE Home Router it is said that it will cater for upto 32 devices.
Highlighted
Sorry thought that was the name of the Smart router. It is Fibre plus broadband.
Highlighted
Re: How many devices connected to fibre broadband?
@Queenvic : Welcome to EE's Home Broadband Forum.
What you been told by whoever you spoke to is a load of tosh. 13 devices would be no problem for a EE SH router. BTW No way were they engineers.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
3. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
