by david759 Established Contributor
How long for full speed after fixing a line problem
I had a line problem which caused no dial tone and slow broadband speeds. This was fixed by an OpenReach engineer 7 days ago but my download speed is still only 8Mbps. It used to be 40. When will the speed return to normal?
9 REPLIES 9
Re: How long for full speed after fixing a line problem
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
2. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
System Uptime is: 164:45:48
Current Time/Date is: 10:31:32 16 Oct
Status
                                Configured     Current
Line Status             --                      UP
Link Type                --                      Fast Path
Operation Mode     Automatic     G.993.2 (VDSL2)
Data Rate Information
Upstream                8653 (Kbps)
Downstream           8800 (Kbps)
Defect/Failure Indication
Operation Data       Upstream     Downstream
Noise Margin          5.2 (dB)         25.9 (dB)
Line Attenuation    0.0 (dB)        22.6 (dB)
Indicator Name                                  Near End Indicator     Far End Indicator
Output Power                                    5.8 (dBm)                     11.5 (dBm)
Fast Path FEC Correction                 1051                              5008
Interleaved Path FEC Correction     --                                    --
Fast Path CRC Error                          0                                    0
Interleaved Path CRC Error              --                                    --
Loss of Signal Defect                        2                                    0
Fast Path HEC Error STR                  0                                    0
Interleaved Path HEC Error              --                                    --
Error Seconds                                    21                                   36
Statistics
Received Data                                    28499245 (Kbits)
Transmitted Data                               24556113 (Kbits)
Have I missed any information? Original fault number is 219627674.
Also, it isn't just the drop in raw speed from 40Mbps to 8Mbps, latency for point to point connectsions seems much worse as well.
BT Broadband Availability Checker ?
We know nowt about your fault no. This user discussion forum can have no access to your a/c.
Copy and paste doesn't work well, so attached as a picture.
I had a 40Mbps connection before, when will it be restored?
I think that the DLM system has put you on a banded profile in response to past errors on your line. You need to call EE to reset the DLM in order to remove any banding. However should significant errors persist the DLM will reapply banding.
This is not what I was told by EE support - wait 10 days and it will all magically sort itself out, they said.
Ah, ha, the mythical 10 days training!
I called EE this morning. They did a line check and found another fault, this time at the exchange end. So I guess a few more days running at 20%.
