by Smitchelson
How do i get a replacement smart hub?
6 REPLIES 6
by Ace Contributor
Re: How do i get a replacement smart hub?
Hi @Smitchelson
Welcome to the EE Community,
You need to speak with the EE broadband technical support team.
0800 079 8586 Option 3 for Home Broadband & EE TV.
Thanks,
David.
Why? Is it faulty? In what way?
Morning @Smitchelson
Welcome to the community 🙂
Are you having problems with your Smart Hub?
If you can let us know, we will see what we can do to help 🙂
Thanks.
by Smitchelson
Hi yes I am we have to keep switching it on and off to reset works for a
while then stops again, can you arrange for a replacement please Thanks Sam
Mitchelson
You will need to phone EE & explain the problem & ask for a replacement router.
Hi there @Smitchelson
Thanks for coming back to us.
If you give our Broadband Tech team a call on 0800 079 8586 they can get this looked into for you.
Leanne 🙂
