by lord_lordy Investigator
How do I use my EE Smart hub as a router only
I have just got a new Smart Hub and want to use it to extend my network at home. This means I don't want it to be my access to the internet but instead just act as a router within my network and provide a wifi at a far part of the house.
Is this possible ?
I have managed to set it up so it all works correctly when wired (by switching off it's DNS server). But it's wireless network doesn't connect to the internet. Now I can't log on to the box to try adn change things - i believe because it's got a different IP now BUT I can't see it when I go to my main routers status page. I've tried factory reset on it to start again but that doesn't work. I then disconnected from my network but then when I try to login as admin it tells me  I can't because it's not online.
I'm now very confused so any help much appreciated
8 REPLIES 8
Re: How do I use my EE Smart hub as a router only
You mean you don't want to use it as the modem connecting to the BB?
Are you feeding it thro' its WAN port 4 from the main router?
How are you setting up IP ranges of it & the main router?
DNS has nowt to do with routing..
Factory reset will always put it back to what it was. Have you tested it on its own?
I tried the WAN 4 Port but didn't seem to work (but that clearly shoudl have been something else).
DNS - may have used wrong term - what I (think I) did was switch off the IP generation on that router
Have not set IP Range - didn't think I needed to if it got it's IP from main router and used main router to allocate IPs
Not sure I did factory reset correctly as I just couldn't get to log back in to the smart hub as admin. I had it disconnected from the main router thinking htat would sort the problem.
From your response I'm assuming that I should be able to do what I'm trying to do.
forgot to say in previous post. You are correct I don't wnat to use it as the modem connecting to BB. My connection is all ok so didn't plan to mess with it - instead I want to place this is in a far part of the house (with a wired connection) and create a wifi network there.
OIC! You have disabled the DHCP, the bit that allocates IPs. You are not trying to turn it into a router but into a bridge.
Here's one I did earlier with Brightboxes: To make a second Brightbox as a WAP on your LAN to the main Brightbox . I do have a more advanced version where both act as routers (DHCP & NAT enabled).
I still believe you should be using WAN Port 4. That is where the Net is coming from/going to & it should be bypassing the modem.
Have you made the wireless SSIDs identical on both routers?
My feeling is that it can't be done with SHs as they are considerably dumbed-down by BT & don't have the controllability of Brightboxes.
Thanks for the link. I am struggling to find where I make even the first change it suggests:
Set Broadband Type of Secondary BB = Fibre/Ethernet for a BB1 or Ethernet for a BB2 (untick the "Enable ADSL/Fibre auto sensing" 1st), under Basic Settings
I can't find basic settings after I've logged in as admin - can you tell me where to find it ?
You can't! That's where the SH is dumbed down.
Those instructions are for a Brightbox not a SH. I only showed you that as an example of using a router as a Bridge which it appears you are trying to do.
argh, So you're telling me this is not possible ? I was confused as I thought you were saying it could be done.
I was getting so frustrated - since i've done this with other routers and was cursing how bad this one was.
No. I said it can be done with other routers (as you yourself have found) but I felt that it can't be done with the SH cuz of its dumbing down & lack of controllability that other routers have.
