by Tania_Y Investigator
How do I set up usb with Brightbox router and windows 7 professional?
I'm currently using Wifi and want to change over to using USB. I've become very sensitive to EMF and for health reasons want to disable WiFi.
I only have instructions on how to set up WiFi. How do I disable this and connect USB to my laptop. My operating system is Windows 7 Professional and I have a BrightBox router. Also what USB cables do I use?
Re: How do I set up usb with Brightbox router and windows 7 professional?
You can't connect to a router using USB. If you want a non-wireless & preferable solution then use the Ethernet cable that came with router to connect the PC to the router.
I haven't got a cable that connects to the router.How do I get hold of one from EE?
| | Virus-free. www.avast.com |
It should be in the router box. Phone CS for 1 if it was missing.
No I don't have the cable.
Thanks for the help.
Thanks! You're welcome :)! Glad I could be of assistance.
You can buy an Ethernet cable practically anywhere. Search on Google.
