by Arty459
How do I improve my broa speed away from the router
How do I improve my broadband speed away from the router?
by Arty459
Broadband speed
Re: How do I improve my broa speed away from the router
@Arty459   You could try reposition the router to another location as it depends on what devices are near it  as it could be getting interference after this your only option is to increase your broadband tariff.
You could try installing a WiFi Range Extender
Re: Broadband speed
@Arty459   You need to upgrade your package that you currently have. You could try relocating the router but there is no way of increasing the speed without going to a higher tariff.
quick question how many devices are connected to this router as this will have a knock on effect to speed.   More devices will impact speed.
Re: Broadband speed
@Arty459 : Welcome to EE's Home Broadband Forum.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
