by C19MSS
How do I connect to my sky HD box please?
by Brilliant Contributor
Re: How do I connect to my sky HD box please?
Hello @C19MSS ,
Welcome to the community,
Do you mean you want to connect your Sky box to your TV or your broadband? If it is broadband, then you need to go into settings on the box and scroll down to Network connection to connect.
Did you want to use Sky on your phone, then you need to download the sky app in order to connect.
by C19MSS
I’m trying to connect my wifi wirelessly to my sky+ box to get on demand tv
@C19MSS , I do not have sky, but you need to go into network and you should then be able to click on wifi to connect, but do this via your sky box.
by Skilled Contributor
Skilled Contributor
Does your Sky Box have a wireless adapter?
You could just follow the Sky Help guides here.
