by pigsonthewing Investigator
How do I connect a Linux laptop to the BrightBox?
I just switched my parents to EE Broadband. Every device they have, and mine, have connected, first time and without problems, to the new hub.
Except their laptop, which is running Linux Mint.
That just keeps asking for the password, which has already been entered correctly. The laptop connected to the old BT hub without problem.
I've tried making the laptop forget the network then reconnecting, and I've restarted it. All to no avail.
What now?
Solution
Re: How do I connect a Linux laptop to the BrightBox?
Turns out I'd been given the wrong password! Because it was only one letter out, and a homynym, I didn't notice. Thanks, everone, for your help.
7 REPLIES 7
EE Employee
Re: How do I connect a Linux laptop to the ?
Hi @pigsonthewing and welcome to the Community.
I will certainly try and assist, I sit next to a Linux guru (luckily enough)
So I/we can try and help 🙂 please may I take the following:
  • Which router, it is that you're using?
  • Which Version on Mint is it that you have?
Many thanks,
Lee
Selecting the router's SSID from the list of WiFi netwoks & typing in its WiFi password should work from any device.
If you have the Brighbox 2, have you tried both the 5 GHz & 2.4 GHz bands?
Yes, it should do, but it does not.
5 GHz is not an option; the laptop (~ six years old) does not recognise it.
The router is a BrightBox2, delivered from EE a few days ago. The laptop is running Mint 18.1, 64 bit, with Cmmamon 3.2.7.
EE Employee
Hi @pigsonthewing
I will get my colleague to have a look into this for you as he has all the equipment to try and replicate your issue.
Many thanks,
Lee
Solution
EE Employee
