Highlighted
How do I conduct a 3-way call on the landline?
Hi - I know this may be an old question, but there are probably new answers!
Can I conduct a 3-way call from my EE landline, and what are the charges likely to be if one of the paricipants is in New Zealand, and the other on TalkTalk?
Highlighted
by Ace Contributor
Re: How do I conduct a 3-way call on the landline?
Hi @PaulZ
Welcome to the EE Community,
How to use 3 Way Calling...
Dial the first number
then press the recall button on your telephone keypad.
Wait for the dialling tone
Dial the second number.
When the call is answered,
press recall
Wait for the dialling tone,
then press 3
To talk to each caller separately, press 2 instead of 3 when the second call is answered
To switch between callers: press recall, wait for the dialling tone, then press 2 to end the call entirely, just hang up to end the first call only: press recall, wait for the dialling tone, then press 5
To end the second call only: press recall, wait for the dialling tone, then press 7
Highlighted
by Ace Contributor
