by Hughie1951 Investigator
How do I change my home phone greeting
Hi
I have 1571 enabled on my landline but can't find any instructions about changing the greeting message from the default to a personal greeting?
Solution
Re: How do I change my home phone greeting
Ah, OK! It seems that EE has not adopted the full BT 1571 service. Probably cuz it's free while BT charge £3.50 pm.
6 REPLIES 6
Dial 1571 - Opt 2 - then either:
  1. To use a personal greeting.
  2. To use the standard greeting.
Hi there @Hughie1951
Welcome to the community.
If you can try the advice from @XRaySpeX and let us know how you get on 🙂
Thanks for your replies.
Unfotunately when I dial 1571 I just get my messages. There are no options. Once the messages have been played that's it.
Solution
Kind of explains it I suppose. Piry it's not mentioned by EE with the other 1571 info; could've saved me a lot of time .... but thanks anyway.
EE give no info about 1571 except that it's voicemail.
Thanks! You're welcome :)! Glad I could be of assistance.
