by Burt_Gander Investigator
How can I check how much Data I how used on my Alcatel Router
Is there any way of ''keeping tabs'' on how much I have used on a weekly, or daily, basis?
Cheers
7 REPLIES 7
Re: How can I check how much Data I how used on my Alcatel Router
Is that a mobile BB router? If so, you can see how much data you have left by going to http://add-on.ee.co.uk/status .
thanks - but this is a Home Router
For fixed Home BB look in your MyEE for BB under Recent data usage . EE provide various usage analyses.
I never look at it myself. Why are you interested in this when you have unlimited usage anyway?
EE dont do a Home Router with unlimited Data - I am on the 55 quid package which limits you to 100mb of data
Cheers
I thought it didn't until you implied it wasn't a mobile BB router.
As I said earlier all you can find out about a mobile BB router is how much data allowance has been used and is left.
We have been talking at cross purposes.
Good Morning @Burt_Gander.
If you're using the 4GEE Home Router, you will be able to check your data allowance using the link that @XRaySpeX provided.
Do you get any errors when trying to check?
Do you know how much data you get monthly?
Jon
I expect you mean 100 GB.
