by David-q1 Investigator
Home broadband connection now very slow and patch - for last two days
Hello,
My previously working and reliable home broadband has slowed right down and cuts in and out. This has happened for the last 48-72 hours.
I use wireless devices and they are all affected the same.
Help would be appreciated.
Regards,
David
Re: Home broadband connection now very slow and patch - for last two days
DSL STATUS
This page shows information about your DSL connection. If you are using Fibre/Ethernet Broadband then this page is not applicable.
STATUS
Configured Current
Line Status -- UP
Link Type -- Interleaved Path
Operation Mode Automatic G.992.1 (G.DMT)
DATA RATE INFORMATION
Upstream 448 (Kbps)
Downstream 8128 (Kbps)
DEFECT/FAILURE INDICATION
Operation Data Upstream Downstream
Noise Margin 27.0 (dB) 11.7 (dB)
Line Attenuation 0.5 (dB) 2.5 (dB)
Indicator Name Near End Indicator Far End Indicator
Output Power 12.1 (dBm) 7.8 (dBm)
Fast Path FEC Correction -- --
Interleaved Path FEC Correction 0 0
Fast Path CRC Error -- --
Interleaved Path CRC Error 0 0
Loss Of Signal Defect 0 0
Fast Path HEC Error STR -- --
Interleaved Path HEC Error 0 0
Error Seconds 0 0
STATISTICS
Received Data 5696235 (Kbits)
Transmitted Data 397058 (Kbits)
SYSTEM LOG
This page shows various system events like administrator login/logout, broadband connection status.
System Uptime is: 33:19:01
Current Time/Date is: 10:29:39 21 Sep
Hi @David-q1
Welcome to the community. 🙂
I think @XRaySpeX will be able to help with this when logged in.
Please check out our broadband speed help page in the mean time.
Chris 🙂
There's nowt wrong with your BB. It's running at full speed with no discons in 33 hours.
Therefore the issue could be:
  1. The WiFi within your home. This can be unreliable & variable. To the best outta BB you really need to be using Ethernet connections.
  2. Congestion at the exchange.
  3. Faulty router. Try factory resetting it.
1. Try a wired speedtest here http://www.thinkbroadband.com/speedtest.html and copy to here just the "Link to this result:" link.
2. What exchange are you connected to? If you don't know use: http://www.samknows.com/broadband/exchange_search and post the URL of your exchange page.
Thanks for having a look Spex. There was a considerable change in speed and connection kept dropping. Speed tests were 2Mb... when working at all.
I found a contact number for EE who have investigated and there is a fault with the line between house and the exchange box. Openreach are down to fix in 2-4 days.
thanks, D
