by ms7979 Investigator
Home Router Huawei E5180
Trying to connect a wireless printer to the Huawei E5180 on EE. How do i activate WPS on the device?
Solution
Re: Home Router Huawei E5180
Yes, the B593 does have WPS functionality.
See HUAWEI B593 Quick Start Guide .
by Profile closed
Not applicable
Hello @ms7979 the 4GEE home router does not come with WPS functionality I am sorry, you would need to connect the printer manually using the SSID/password as normal. 🙂
 Hi, many thansk for this. I had a feeling this maybe the case. Does the Huawei B593 support this do you know?
Solution
@WilliamJ: No, read the reply to the OP in https://community.ee.co.uk/t5/Broadband-home-phone/Home-Router-Huawei-E5180/m-p/548765/highlight/tru... .
You have alighted on an old thread about a previous EE offering of an MBB router, not to be confused with the current 4GEE Home Router , which also does not do WPS.
