by hebe4g Contributor
Higher ping after transfer from SSE to EE
Hi
My account transferred yesterday from SSE to EE. While I'd say the the overal capacity has increased from about 65meg to 74meg, I have noticed the ping increase from 6MS before to more like 15ms. Furthermore, it does not make any difference whether I use the EE provided router/modem or my own.
Is this something that can be addressed? Or am I stuck with it?
Solution
Re: Higher ping after transfer from SSE to EE
Um! A pretty uninformative router.
With BB there are 2 types of latency path: Either FAST or INTERLEAVED. Fast is normal mode, Interleaving can be applied to the line to help increase stability. Unfortunately this router does not tell you which you are on (most do!).
The ping to the BBC will typically be:
  • Fast Path: 5 -10 ms.
  • Interleaved Path: 15 - 20 ms.
Seems you must be on the latter. All you can do is give it time for the DLM to work out that your line is stable enough to switch it to Fast Path. Alternatively after about 10 days if it hasn't improved you could ask EE to do a DLM reset but BT OR will be loath to do that unless they are actually fixing a line fault.
12 REPLIES 12
Good Afternoon @hebe4g
Is this a fixed broadband connection?
Have you spoke with our technical team to see if there is anything further you can do?
Speak soon,
Katie:)
What is your ping to bbc.co.uk ?
Please post your full router stats.
Phoning CS after only 1 day with EE will only result in being told to wait the mythical 7-10 day stabilisation period.
Hi
Its about  15 as I said...
PING bbc.co.uk (151.101.64.81): 56 data bytes
64 bytes from 151.101.64.81: icmp_seq=0 ttl=55 time=15.618 ms
64 bytes from 151.101.64.81: icmp_seq=1 ttl=55 time=16.174 ms
64 bytes from 151.101.64.81: icmp_seq=2 ttl=55 time=17.695 ms
64 bytes from 151.101.64.81: icmp_seq=3 ttl=55 time=17.568 ms
64 bytes from 151.101.64.81: icmp_seq=4 ttl=55 time=17.809 ms
64 bytes from 151.101.64.81: icmp_seq=5 ttl=55 time=16.890 ms
bbc.co.uk 64 bytes from 151.101.64.81: icmp_seq=6 ttl=55 time=17.077 ms
64 bytes from 151.101.64.81: icmp_seq=7 ttl=55 time=16.968 ms
64 bytes from 151.101.64.81: icmp_seq=8 ttl=55 time=15.728 ms
64 bytes from 151.101.64.81: icmp_seq=9 ttl=55 time=212.980 ms
Exactly.
Now if I can see your full router stats I may be able to explain that.
Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Sorry, yes, here is the log:
Product nameEE Smart Hub
Serial number1843004228
Firmware versionv0.00.24.06190-EE (Tue Jun 19 17:25:19 2018)
Board version1
Data sent / received1.5 MB / 10.4 MB
DSL uptime0 days 0 Hours 11 Mins 3 Secs
Data rate20.00 Mbps/78.75 Mbps
Maximum Data rate26.1 Mbps/91.6 Mbps
Noise margin (up/down)9.4/6.3
Line attenuation (up/down)16.8/16.0
Signal attenuation (up/down)16.6/16.0
Broadband usernamePRODUCTIONXXXXXXX
2.4 GHz wireless network nameEE-Hub-XXXX
2.4 GHz wireless channelSmart (Channel 6)
5 GHz wireless network nameEE-Hub-XXXX
5 GHz wireless channelSmart (Channel 48)
Wireless SecurityWPA
Wireless modeMode 1
FirewallDefault
MAC addressXx:XX:XX:XX:XX:XX
Software variant-
Boot loader 0.0.3-EE (Mon Dec  4 17:32:53 2017)
Solution
Thankyou for a highly informative reply.
Thanks! You're welcome :)! Glad I could be of assistance.
Incidentally, the ping has come right down to 6 all by itself. So the mythical 10 day thing is clearly true!
Not really! The DLM is continually monitoring your line & has clearly decided your line is stable enough to cope with Fast Path.
