by kindaweirdm8 Contributor
High jitter
Recently my ping has been jumping up and down from 40-250 which isn't good when i'm gaming, haven't had any issues in a long time now but noticed this today playing league of legends. Ping test example - https://imgur.com/a/Tfa00xq
Re: High jitter
Hi @kindaweirdm8
5G or 4G?
That doesn't look abnormal.
Re: High jitter
Hi there it's 5g, Haven't had this problem for over a year maybe, it was at a constant 40-60 before. Also with an Ethernet cable fyi.
Re: High jitter
Hi @kindaweirdm8
5G is still new so it's likely that is the cause, keep an eye on it and if it becomes more erratic then give EE CS a call.
Also check and log any problems on EE Network Status Checker.
Re: High jitter
Yeah it's still happening, thought it was resolved but i was wrong. back to 100-250 ping which is really bad. I will call in then.
Re: High jitter
